Running lights
Where could I look for ideas to place running lights on the rear of my 2015 ST Special Ed. ??
Ste sponcer Tricled did mine
attachment.php
fyi the long led on top installed at spyderfest last year are tail & brake. The small led are rivco just brake & modulate :thumbup:
Well....
I 'd say you are outta room... if all those showing are brake lights maybe change some to running lights. Double strip the grab bar with one for running. I added a second set of turn signals and use those for brakes but you could run them as running light....Then there is the fender...:dontknow:
attachment.php
Wig Wag and/or in addition to Extra rear brake lights?
Has anyone added extra brake lights such as Value Accessories' item or is that what is showing in the photo...? http://store.valueaccessories.net/LEDRunningBrakeLightsCan-AMSpyderST.aspx
And has anyone tried the Wig-Wag on their ST-S? http://www.signaldynamics.com/backoffwigwag
I was told the Wig Wag should work, but should and will are not the same. And I'm not technical enough to do much electrical work on my ride. :banghead:
What I'd like is to add something like the extra brake lights along with the Wig Wag...thoughts??
Fyi my pic they (long ones) tricled not valueaccessories, & installed @ spyderfest. They do running & brake. The smaller ones are rivico "SOMA" lights & modulate when brake is on:thumbup:
they offer kits to mount them by lic plate & you can pick constant modulation or 5s when installing. The wig wag sounds fine but may not handel much load, I did not wanna risk it is why I only kept the modulator to the ones it came with. Email them & find out.
Caution on mounting strips on the grab bars. I did this on one of my Spyders but frequently push/pull the bike around my garage. Not paying attention I have grabbed the strip and both pulled it off and rubbed off the clear layer of the strip. I replaced the strips and put them on the underside, on the splash plate and they look amazing.
