RTS Rear Shock Replacement
TRBorslien
The wife was complaining this season about some of the new bumps and potholes hurting more than last year. I tried to miss the bad ones and slow down a little. Also made sure the air bag switch was at maximum setting.
A week ago she complained again and I hit the switch and the MANUAL error code showed up. Checked the air bag after the ride and it said zero psi. The rear Kenda was done, so I decided it was the right time to order a Kumho and troubleshoot the ACS while the wheel was off.
Crawled underneath to remove the lower rear shock bolt and found it wet. :mad:
Finished pulling the wheel and dropped it off to get the tire installed. Ordered a new rear shock. Lots of up and down to put together the right combination of tools to remove the upper bolt. :mad:
Finally had the shock in my hand. Tire looks great, but the new shock hadn't arrived yet.
Got the shock last night and could not get the spring compressed to swap it over. I tried to fit my automotive compressor and couldn't get it on, tried ratchet straps and it wasn't budging, checked the auto parts tool rentals and none would fit. Gave up and brought it in to my favorite shop: Dave's West Fargo. Owner is a rider - not Spyder, but two wheels. He was surprised by how hard his press worked to compress the spring, but then he realized it was holding a lot more weight alone then some bikes do with two.
Disconnected ACS dump valve and will manually inflate air bag through the riding season. I will be tearing into it for plugs, wires, brakes, and other things this winter, so I will look at the ACS then and make a decision.
Did lots of research here and found that the upper bolt can be accessed by removing the rear bags. Removed all of the side panels and can get at the nut on the left side without removing the bags. The compressor is in the way on the right side, but a 3/8" long-handled breaker bar with socket will hold the bolt from underneath with the tire removed. So decided to leave the bags on and so it that way. I can still torque the nut without any trouble.
Two lessons:
1. It probably doesn't hurt to occasionally verify that the air bag has air in it even if you have ACS. My blown shock could be due to excessive travel caused by riding with an empty air bag. :banghead:
2. That spring is no joke, anyone facing a rear shock replacement might want to line someone up in advance to swap the spring over to the new shock. Unfortunately, my local dealer doesn't have the special Can Am tool.
My Friday night will be spent installing the shock and new tire, but the test ride will be worth it. :ohyea:
Two lessons:
Howdy, Mr. T!
Thankee fer this post. Good advice. One more special tool to bug me dealer aboot, lol!
Hope everything goes back together fer ye.
Cheers!
E
Can I ask what you got for a new shock i understand you can buy a shock spring compo that increases your payload from 550 to 700 lbs.
Hi Steviep,
I just replaced it with the OEM shock. By the way, the part number has changed to 706001262. I am guessing that BRP came up with an improved? shock in 2013 or 2014 and made the new part number retroactive to 2012. I didn't dig any deeper into that, I just wanted to replace the shock.
Sorry for the late reply, the wife and I just got back from a 1300 mile trip on the new shock and new rear tire. Felt like a new bike! :2thumbs:
Hi Dave,
I had 27,250 miles when the rear shock failed. It should have lasted longer based on what I've read here on the forum. That is why I suspect all that two-up riding this year with nothing in the air bag might have accelerated the shock failure. I know OEM shocks are designed to bottom out, but not frequently. I briefly considered a better shock, but I just wanted to get the bike back on the road. I have read some stories about people replacing the shock and air bag with one assembly. I might consider that as a winter project.
I am not the original owner, but I am sure the Kenda rear was not the original. The PO had all the tires overfilled so the rear was bald in the center with some tread left on the outsides. The front Kendas are getting close, so I will have to replace them sometime this summer too.
We are getting a very nice ride with 15 or 16 psi in the front Kendas, 20 psi in the rear Kumho, the front shocks at highest setting, and the air bag around 80 psi.
I just replaced my rear shock with a M2 on a 2014 RT and used a offset wrench and a 15MM socket with a log extension. No need to remove the luggage bags.
Then used a jack lifted the bike a bit and removed the lower shock bolt.
First removed the swing arm switch first.
