Most excellent info - thanks
Dan -
Thanks for the insight.
I agree about spring rate and ride comfort. A lot of people on the forums do not understand that stiffer springs make bumps bumpier!
From the suspension gurus in the books(s) softer springs make for better handling/wheel to road compliance. There are always trade-offs and softer means big chance of bottoming to the jounce stops. Ouch!
Right now I have 250# springs on order. (Again I am relying on Elka's 207# empirical data.) They are 14" versus 9.3 for the oem shocks. Can't reuse stock springs as they are too short and QA1 and other shocks are not threaded high enough on the shock body to get the perch high enough take up the slack on short spring.
My main concern now is the spring diameter. OEM shocks are pretty skinny as are the springs. The O.D. on oem shocks is about 2.5" which is the I.D. of standard coilovers. QA1 told me that the O.D is 3.25 - 3.5" - oh I hope not. There is not that much room in the 'hole' in the wing/upper arm. After doing some spring calculations I get that the O.D. should be around 3 " which will fit. I am waiting for everything to come in so I can see if it will fit. Summit should take it all back ($490) if I did not mount it I am 'purdy sure.'
If it doesn't work out I still have the 2014 oems on order and I may have to break the piggy bank for some Elkas.
Still it is going to be good experience in suspension tuning :banghead: (Experience is what you get when you don't get what you want!
Jim
If you know someone with a set of race car scales the guy might have a
spring rater If so check the rate on your springs then decide what you need
from there. On the shocks your friend may know someone at Pro Shocks in
Lawrenceville Ga that will dyno them for valving so as to make a better choice
on that even as they will have adj. compression & rebound. Just make sure
the new springs are a matched set on height & rate. Heck he might have some
springs in the 10"length you can test with.I know two guys that have the RTs that
use the Ron's bar with the elka 1+r one has the 250 springs & this setup works real
good,the other has the 300 springs & he complaines they are about to beat him to
death on anything on the rough side. I need one of these guys to pull a shock & lets
have it checked for valve rate as that is a well kept secret.
spyder strider
Dan
Dan -
