RT SE Oil Change
JohnE
RT-S PE-0539
I was looking for the oil change post by Lamonster to check if the SE model was covered in his thread. I found it and could not find anything on the SE model. Has this been covered ?
Oil Change on RT - SE
I can highly recommend the 2010 RT shop manual from Midwest Manuals... http://midwestmanuals.com/Motorcycles/can-am.htm ... it is searchable and describes precisely how to change the oil on the SE as well as anything else you will want to know about your RT.. Len
It's the same except you change the little tranny filter the first oil change and then I think it's every 12,000 miles for that filter.
Oil Change
Thanks Lamont
I didn't know if the transmission filter was required for each oil change
Thanks Lamont
When you first look at the SE5 filter area it looks much more crowded than the SM5 pictures BUT the filter comes off and on with no problem!:2thumbs:
The official BRP shop repair manual states... change the HCM, Hydraulic Control Filter, at 600 miles then at 12000 miles then every 12000 miles there after.
"She who must be obeyed" has me change hers every 6 to 8 thousand miles.:shemademe_smilie: For us I believe that is a good policy because filters are less expensive than transmission control modules. /Ken krb1945
