RT key cylinder for trailer
How to ?
Does anyone kown how to remove the key cylinder from the cam am 622 trailer.
Midwest manual - the link below is for 2010 - don't know of any newer, but, it covers both spyder and trailer. Twenty well spent bucks if you so choose. Just remember it will have old info....like belt tension, for example.
I checked mine and it is a twelve step process. Would have copied and pasted them for you, but, it's a protected pdf.
Jer
http://www.midwestmanuals.com/Motorcycles/can-am.htm
One reason I remove the protections from my PDF.
Key Barrel Removal from RT Trailer
1. Remove inner panels.
2. Remove the component support cover plate.
3. Disconnect both latch cables.
4. Remove 4 retaining screws from the latch mechanism assembly.
5. Pull main control handle assembly out if it location towards inside of trailer.
6. Use a small screwdriver to pry out the handle pivot from pivot points.
7. Remove pivot from mechanism.
8. Remove 2 top retaining screws from the latch plate to remove the center blank cover.
9. Remove the center black cover
10. Hold latch plate in place while removing the 2 lower retaining screws as the place is spring loaded.
11. Remove the spring and ball.
12. Remove the key barrel actuator cover.
13. Insert key in key barrel.
14. Turn key 1/2 turn until the retaining tab is aligned with the notch.
15. Insert a small screwdriver in the notch and gently lift the key barrel retaining tab to allow remove of the barrel.
16. While holding retaining tab, push key barrel out of its location.
"One reason I remove the protections from my PDF."
I'm all ears :roflblack:
I am a network security guy. I just remove the encryption from the PDF. If you would like I can do the same for you. As long as you know how to FTP.
Thanks....but it's not worth bothering you. I have a printed version as well as the pdf, suppose I could do a quick scan next time. If needed.
jer
Damn. Would be easier just to buy a new trailer. Can't it just be drilled out?? Then buy new cylinder.
