RT Front Shock adjustment question - Lifting the front?
Kagey_98
Is there a good spot to use a regular scissor jack, to release the pressure on the Front Shock, to adjust them?
Thanks! :helpsmilie:
Just behind the "T" should do. I have the SpyderPops Critter Gitter on mine, os I place the jack imediately after it and things work just fine. It tends to lift the left wheel off a bit and takes enough weight off the right one to make the adjustments possible. You may want to spray a bit of WD40 on the shocks too. It makes it way easier to twist.
