rs-s brake failure
spyderchris-nz
ok... two things going on. changed oil and filters . new front pads also. starts, runs but get brake failure message, and wont go into gear, forward or reverse, topped up brake fluid and bleed them. ifs there's an issue with brakes will the system stop the transmission [se5] from operating ?
thanks for any ideas.
Could you have damaged an abs sensor, or cable...?
pulled up code C1282....low brake pressure detected, possible brake circuit leak, check hydraulic circuit for possible leak. had the message come up before sometimes then its cleared. might need to go to the shop.
