bluestratos
I installed the audiovox on my Suzuki Burgman a year ago. I had to fab some custom brackets but over all it was a relatively easy install. When I took it out for the test run it would not turn on at first so I changed some DIP switch and it worked but, it would not lock in under 60 mph. It took some head scratching but then I realized I had to add more magnets to the wheel. When I did that it worked great. Locked in at 25, and becuase the Burgman was automatic, it stayed locked on through out the gears. I did buy buy a small after market vacuum motor and a vacuum switch to trigger it on and off so it did not run continously. This just allowed my cruise to stay locked on even up long hills when the engine vacuum is less and the vacuum can depletes.
Good luck.
Randy
Good luck.
Randy
