How do you control Rabbits (without shooting)?
One of my friends that has a small farm with trees bordering the property has a ritual he does every night to keep animals off the property.
He drinks a couple of beers then goes out to the treeline and relieves himself along the treeline in between the trees and does a different section every night.
He claims it keeps the animal off the property.
That won't work unless he got a kidney transplant from a wolverine.
From some movie, the deer were eating the football field making it worthless, & someone suggested visiting the local barber for hair clippings to spread out & deter. Worked in the movie, probably just the scent. The rabbits described however, could probably use more robotic/motion activated mechanical measures, even just a rope spinning around (with clanging bells attached) or something fast & flashy on a track. Sorry the foxes were eliminated. Otherwise, non projectile various fireworks can be used properly to help. Had a neighbor DIY an acetylene cannon - a lot of noise & a cool fire ball (an empty 55gal drum with 1 end open; some large cheap balloons; a long stick with a clip attached to hold the balloon. Fill the balloon with acetylene & tie it off; clip to the stick; insert it into the bottom of the drum; ignite however safely you can.) Not not safe at all, but... ya, well.
Additional thought, if you possibly have an old ceiling fan available & few other parts/skills. Mount the fan (no blades) on a sturdy box of a decent height; extension cord with a on/off switch. Maybe use a dolly to move it around your yard easier. Attach a length of rope <20-30ft> (not thin string, thicker ROPE some kind) to the blade mount. Position it where will not strike or tangle on anything; stretch the rope out and attach some kind of cow bell on the end & turn it on. The slack in the rope will keep it jumping for a little while; tho I doubt it will spin fast enough to get straight & tight. It will eventually spool up on the motor & need to be reset or it may burn up.
Anything they do will only be a temporary measure. When the ranchers killed off most of the dingos the balance of predators and prey got out of balance. The dingos were the apex predators that kept all the lower order and herbivores in check naturally. Some other non-native herbivores were introduced and now the balance is so far off that the weather and available food during the breeding season determines which of the lower order animals multiply to the point where only starvation or disease controls their numbers. There is no permanent solution to the over-population by the animals that were once much lower on the food chain unless the apex predators are restored to their former numbers and the ranchers would not allow that. Now the restrictions on firearms just adds fuel to the fires of the out of balance environment. The imbalance was created by humans and so the humans will have to live with it. A lot of people might not like what I write, but I will write the truth, whether anybody admits it or not. Some measures can be taken to limit the numbers of the animals that are multiplying too fast, but that will just be a temporary fix and not a solution, since the real solution is to restore the balance. Only the restoration of the dingo population will control both the balance between the prey and predators and the control of the non-native and lower order predators. The problem will only get worse with over-grazing by both the out of control numbers of native species and the animals introduced for food production and profit.
I think it's just his excuse to drink beer...
The real solution is Dingoes, Dingoes, Dingoes! But Gwolf gave a better explanation. Around here, even in our metropolitan community, Coyotes, Owls, and Hawks keep the critter population in check. We all coexist nicely. I see rabbits daily along with coyotes wandering around. Newbies and people from out of town always seem surprised when the see the "wildlife" wandering and scurrying around in desert neighborhoods. I enjoy quiet evenings listening to the sounds of Owls that nest about 75 yards from me and the howling of Coyotes when they make a kill. I know Coyotes are not native to Australia but Dingoes are their equivalent there. The dilemma is which one you can best deal with....
There weren't ever too many Dingoes in this part of the State/Country, and now, effectively no wild or feral dogs within towns, altho a few thousand years ago, or maybe as much as 10,000 years ago, there was a larger population of Thylacines (commonly called Tasmanian Tigers - considered completely extinct here for at least 2,000 years, and likely extinct in Tasmania now too) but even in Tasmania, where they were more prevalent until early last century, they never had much to do with rabbits (they just weren't ever really interested in them, then their population was decimated pretty much completely around the time the rabbit invasion began, so they never really had a chance to have much effect!)
Even when Europeans first arrived here and the climate was a bit colder, milder, and wetter here in South Oz, Dingoes were largely found further out in the drier areas to the North and to a lesser extent, on the open plains to the South East of the Adelaide Hills, but they were never really prevalent in the Hills themselves. Apparently, the bush was too thick and the climate was a little too cold and wet around here for them (the Hills were somewhat colder and wetter back then than they are now, even in my lifetime 😋 often seeing significant snow in the Winter time), so when rabbits arrived, there weren't really any large-ish predators to keep their numbers in check (well, none except for the Drop Bears, Bunyips, & Carnivorous Kangaroos, most of which had died out locally thousands of years if not millennia ago, leaving those big carnivores considered extremely rare around here... until the Europeans brought in another imported feral species as prey, the Tourist; and when that prey population boomed, the local predator populations of those animals also boomed! ;))
All our locally endemic Owls are pretty small too, never growing too much larger than the average adult human's hand sorta size, so they haven't ever and still don't have much of an impact on rabbits; but as I mentioned earlier, the local Kite, Hawk, and Eagle populations are extremely well fed/gorged on rabbits atm. Their numbers are breeding up, but they don't breed and grow numbers anywhere near as fast as rabbits! So the entire population of predator avian species is having about as much the same impact on the booming rabbit populations as a single vegetarian mouse would have on trying to eat a herd of dead Elephants, especially if the herd of dead Elephants miraculously doubled in size on an almost nightly basis like the rabbit population appears to be doubling - the numbers of rabbits are well beyond just 'exponentially increasing' now! 😣
IIRC, rabbits can become fertile as young as 2-3 months old; the gestation period for a female rabbit, a doe, is about 30 days, and she can have up to 12 kits per litter and up to 12 litters per year (altho the average of both is only about 6); she can then become pregnant again within 24 hours; and even if only half of her offspring are females (altho there's growing evidence that more females than males are generally born per litter!) if you do some basic arithmetic, you should be able to see how the population can increase exponentially rapidly! Just One breeding pair can produce a million breeding offspring in a couple of years or less, and we started here with significantly more than one breeding pair significantly more than 4 years ago, so there's very likely many, many, MANY more rabbits than that around now!! And in the 'almost perfect conditions for them' that we've been experiencing for the last decade or so, they're clearly breeding like only rabbits can!! 😖
The only real impact we've had on rabbit numbers lately has been thru introduced diseases, like myxomatosis and Rabbit Haemorrhagic Disease (calicivirus) but those really only spread rapidly thru the population when the conditions are right for increased mosquito & flea populations; only thru a number of factors, including deliberate breeding with vaccinated domesticate rabbits (they might make cute pets, but breeding/keeping domestic rabbits during these times should be banned!) it only takes a few years for the rabbit population to start building an immunity to a particular strain. All of that adds up to a need to develop and test a new variant of those diseases every few years, then test them to make sure they can't spread to other populations &/or people, before releasing them into the wild rabbit population.
I'm beginning to think we've lost this round, simply by not getting on top of it soon enough, so we probably won't see the rabbit population fall too much until they either eat themselves (and probably us too!) into starvation, or some other disease is developed to cut the numbers!! And as a result of their boom and bust cycle, we'll have following boom and bust cycles in what few species of predators we have left! Who knows, maybe the cane toads will spread this far South and somehow have an impact; but for now, after a sleepless night due to the incessant barking at the rabbits of all the dogs in the neighbourhood, and cos they've completely ignored the ultra-sonic 'rabbit scarer' that I've had out there for a day or so; then this morning, going out to see my 'new', laboriously (& expensively!) installed, just over a metre high, double layered and electrified wire netting fence completely collapsed onto what's left of my lawn by the pure weight of numbers in the dawn rush of at least a couple of hundred rabbits (the fence was still standing at 04:00, altho there were 20 odd rabbits of at least 6 generations inside it by then anyway, obviously the best jumpers. I cleared them out then, only getting bit by the fence once, much to the Child Bride's amusement and the neighbours sudden awakening to the loud and not so deleted expletives! 🤨), I think I'm gonna hafta give up on trying to save the lawn &/or keep it green for now. 😟
Start a movement to convince women that rabbit fur, coats, hats, accessories are the newest best thing. If women want (need) dead rabbit skins, a solution will be found. That's the way things have happened since the days of Eve.....
I have the same problem with deer and believe me I do all I can legally do to solve the problem! You can try all of the snake oil solutions you want, but without the predators out there to balance the scale your sunk in the water. My problem is I need a bigger freezer!!! ;)
There is a plant key to survival in the deserts of South-West America. They tried to kill this tree, calling it a useless weed. When they did manage to partially destroy the Mesquite trees, they also destroyed the land the Mesquite trees had grown on for centuries. Without the Mesquite trees nothing else will grow there and once productive land turns into dry desert, it tends to be blown away by the wind. Once called a useless weed, the Mesquite is key to restoring life to arid areas. Maybe not suitible for Austrailia, but there may be some keystone plants and trees there which could help restore life to the over-grazed soil being destroyed by out of balance fauna reproduction. Whether this can help or not, it is still a lesson in the wisdom of the ancient people of the land and a warning about over use destroying productivity. This same process is repeated thousands of times the world over. The lesson goes deeper than just the soil, since the food source from the Mesquite is also the key to stopping diabities and over-weight problems in the populations eating too much refined sugar. The food and sweeteners from the Mesquite pods do not lead to bad health and early death like the sweeteners currently in use.
45 years ago, out in Arizona, New Mexico, and Texas there were rabbits that had long ears. They were everywhere! When they stood up they were about 15 inches tall. The fuel crossover lines were 12 inches tall. I'm sure i cleaned off many rabbit ears through the years! I forgot to mention, they wouldn't move, just stood in one spot!
Good luck with your Bugs Bunny problem sir!
I just saw an article that said spreading strong smelling soap around the yard and garden will keep critters away. No grass or garden in my yard. It's all desert gravel with metal plants and one big saguaro cactus. No maintenance. I get the odd weed popping up occasionally. Yesterday, I saw a bunny munching on one of my weeds. I was careful to not scare him away.......
