Rough riding in first gear
jima
Hi all I have a 2013 st/s bs in first gear 0 to25
it is such a rough shaking ride and fi you try to for e it I to second gear it Gos right
back to first tear (it a se5 trans ) and in second gear it seem to be ok
so is the beast just like to go fast are is their something wrong . All advise is welcomed
Hard to say..!!
does it happen all the time or just initially..? Does it feel like clutch clatter or gears..? Does it do it in reverse as well..? Is it better if you let the motor warm up more..? Hard to think it would be gears. If you oil level is good (checked as stated in your manual) and your oil is fresh as well as the filters you will need to run it to the dealer and have them did a bit deeper...:thumbup:
