My new roadster has less than 1000 miles on it and today I was told my right brake light was not working. Suspect the bike was never actually inspected at pre-delivery, but that the list of items was simply checked off assuming a new bike would have all working.
I can assume the fuse is intact as the left brake light works fine. So, what might be the problem? Or, where should I begin the process of checking. My first guess is a connection is either off or at least not making good contact.
To return this to the dealer for correction is about as much work as figuring out the problem myself, or at least eliminating as many easy answers as I can. Like the actual connection to the brake light unit itself would be the first place I might check, and measuring the voltage at the wire.
If there are any ideas I would appreciate hearing them. Thanks
