I am new to the Spyder community. I saw a video about the Ride-on product. I have two questions, does it really work as a sealant, and does it really serve to balance my tires? Any thoughts on this would be appreciated.
I have used ride on for years. I have found objects embedded in tires when they finally wore out that would have caused flats without the ride on.
No mess. Totally washes away with soap & water. And no worries of corrosion on the wheel either. Great product. Get some for peace of mind, and you won't be sorry.:doorag:What kind of mess is caused when changing tires ?
I believe a few have contacted the company and they rep had stated that the automotive version should be used but I would call them and make sure.
I Use it and I like it!:doorag:
Are there any downsides to using this product?
Motorcycle shop near me will install the rear tire for me but can't balance it for 1 reason or another. Can i add this stuff through the valve stem to balance the tire? cheaper alternative?
If your tires are already balanced do you pull the weights off when you add the Ride-On?? I just had new tires put on my Victory and the front tire has a little vibration in it. The rear tire is good and the tires on the Spyder ride smooth as well but I want to add Ride for the sealing ability.
