rugercharger
hi what has been anyones experience with using this product. also if you have, how has it worked in cold weather when starting out. i am considering using this for the puncture insurance.
Nitrogen filled tires recommended by the Dealer's Service Manager. Comments?
I use Ride-On. I like it. It really doesn't make a mess and it clings to the tread area of the tire. It does a good job of balancing the tire. My tire guy doesn't mind it when changing tires. The sealant never gets anywhere near the bead of the tire where a tire machine works. It would be a bit of a pain for applying an inside patch. But if you're using a plug design, then it wouldn't make any difference.
I use the car version in my Spyder. Ride-On used to recommend the car version for the Spyder. Made sense because the Spyder uses car tires. Now Ride-On recommends the motorcycle version in the Spyder. Tried it. Didn't work nearly as well for balancing. Went back to the car version. It's less expensive as well.
When it sits for a few weeks it may take a few miles for the Ride-On to re-balance the tire. So you get a mild thump for a few miles. But not a big deal.
This has been my experience as well, I have used ride on in 4 sets of tires with no ill effects.
As for cold weather areas my Michigan experience was that it took a few more miles for the balancing to take effect.
