NZSpyderRyder
Has any of the ST limited owners out there removed the RH footplate ? Are the RT footplates the same ?
The reason that I'm asking is because I have just received the instructions for the Eazy Rizer Big Blue spyder lift, they are now in stock in Australia and I made an enquiry about purchasing one.
On reading the instructions it looks like you can't get the lift in the correct position if you have the footplates fitted, hence the need to remove the RH side one, I've had a quick look and it doesn't look like a job you want to be doing every time you want to lift the spyder.
Is there some kind of safety feature to with the foot brake built into it as it is mounted completely differently to the LH side ?
I don't want to remove it and fit a foot peg as I like my feet firmly planted on the footplates, I find it makes the ride comfortable for me.
Also does anyone know if the chassis on the 2013 ST differs from other models ?
This will be a major investment so I want to get it right.
