Replacement fuel gauge
Analogue fuel and water temp gauges
I modified mine with a switch so that I can use either analogue or digital guages, selectable on start up... incidentally, my analogue fuel gauge is rather accurate, stable and consistent....
All of the electrical connections should be removed from the gauges.
The digital gauges will appear after start up.
Actually you can flip the connectors upside down (so the sense wire is not connected) and still have the lights work in the analog gauges.
I did this for a while until I finally decided to use the holes for the analog gauges for something else.
Bob
