groundeffect
Registered User
Hey!
Quick question regarding the rear axle assembly and the maintenance item in the manual "Bearing seals, O-rings and wear sleeves of rear axle".
I have identified the following items to be replaced for this maintenance task (I think) ... wondering if you could pass your thoughts on if I am missing anything from the diagram to be replaced, as per the manual for the 20,000km (12,000mile) service.?!
2 of #29 SPACER BRP P/N: 705 500 773
2 of #27 - SEAL (same as #26): BRP P/N: 293 200 094
1 of #28 - SPACER BRP P/N: 705 500 853
2 of #35 - ORING BRP P/N: 293 300 131
I've inspected the bearings with the assembly together and they seem ok but I will take a closer look once I get the rear wheel off.
Thanks in advance, feedback would be greatly appreciated.
