Repair of front trunk
abrinte
Hi
Does anyone know how to replace the wire for the trunk and how to access the assembly under the steering wheel?
Do you mean the handlebars ????? :joke:
The wire is connected to the ignition switch, and to access it you must remove the handle bar cover. There are bolts underneath the handlebar cover and if I remember correctly are 8mm and 10mm. I'm not sure what path the wire takes to get to the trunk so I'm not sure how difficult the rest of the replacment will be. The handlebar cover removal alone will take time and plenty of patience so good luck. :thumbup:
Someone posted a picture awhile ago with the bolt locations on the handlebar cover and if sombody remembers it, please post it for this guy because it will help him get an idea where they are.
