Noticed a difference right away. Idle rpms dropped from 900 to 800 and the engine sounds like its purring! Will try the 100 next.![]()
I use 91 eth.Free from shell or mix with reg 91Have 2014 Rt . Regular gas or premium
I think the 1330 calls for 87 minimum. I dont have one, but I am pretty sure about that. Someone will correct me if I am wrong. You also have to watch for the high octane. Here it is 93, it does not sell that well and it sits in the tanks and then you get the separation of the ethanol. I just had a bad tank of 93 about 2 weeks ago.
" Amen Brother ".......let everyone else feed the Corporate coffers.....:gaah:...:roflblack: :roflblack: :roflblack: .......:thumbup:..MikeMy 2014 RTL has 11,000 miles and has had 87 octane from day 1, never had a problem.
My wife's 2011 RTL is running the same, over 17,000 and no problem.
0992
:lecturef_smilie: What does your owner's manual say about this?
Do you think that they'd lie to you about it? :dontknow:
\:yikes:...........And you if follow it, and do what it says YOU WILL GO BROKE FAST......BECAUSE ....The manual tells you for practically every problem that occurs with your Spyder to " HAVE IT TOWED TO THE NEAREST DEALER....... IMMEDIATELY ". Good luck with that......Mike :thumbup:
Hi Mike,
I can afford to waste my money on more octane for my bike... :thumbup:
...Just as you can afford to waste your money on cigarettes...![]()
