Rebooting?
aka1004
My spyder flashed check transmission light after being transported in gear. It was stuck in gear and would not shift so manually put it neutral and disconnected battery for 15 minutes reconnected and that got rid of fault light and was shifting again til I started it this morning and check transmission light Is back and won't shift out of neutral.
Wasn't there a way to reboot the spyder by turning key on and off few times?
Do you start at off position or on?
How long do you wait before you restart?
Thank you in advance.
I don't know much about the working of the Semi Auto, But is the oil up to the proper level, and the battery fully charged??
