Rear tire size for 2011 RS
Should work..!!
you will have a variation in the speed and distance readings. Speed you can check with gps. Depends on how important that is to you other wise should be fine..:thumbup:
Unless you have an overwhelming reason for the bigger tire, I wouldn't risk upsetting the nanny.. she is so picky....
So I read on this board that the 60R is better for tracking of the bike MPH to GPS readings and since the standard tire is 225, that is why I went with the 225/60R/15
So my dealer is telling me that my 225/60r/15 rear tire is rubbing the rear fender - standard size is 225/50r/15 - I have not seen the bike has anyone put on the 225/60r/15 before - do I have to shim the rear fender up? or will this just not work?
I thought that it might be a bit tall for your application; I was keeping my fingers crossed that it would work... :shocked:
