Rear tire disappointment - OEM Tire worn out already!
I checked YouTube for instructions with no luck. Is there access under either seat? Also, what's a "good" pressure for 2 up?
Yes, there is access to the schraeder valve under the seat on the ‘16 F3 Touring models, narygancy. I have sold my F3 so I can’t remember exactly where, unfortunately. If you remove the rear seat first, you may see the valve. If you can’t see it, remove the front seat (2 small bolts at rear of seat... but keep a magnet on them or you may drop them into the black hole). You will definitely see the schraeder valve then.
I’m 300lbs and was running at 75lbs... but there is a formula in the operator's manual, and on a plaque on the body (I think it is on the left side, below the seat??). Hopefully someone with more thorough knowledge will chime in shortly;)
Pete
Pete
Thanks Pete. I found another forum thread with some info on this, I plan to check my bike out soon. In the other thread some folks say the bladder loses air every few days, some say no problem at all. I bought it from a smallish female who always rode 1 up, so it wasn't an issue for her. Even using the Kenda there was no problem, only since I replaced the tire. You've been a lot of help. This is my first Can Am, I love it, and I continue to learn. Gary
I probably had to top up every month or so, Gary. I suppose I could have done some thorough checking of the fittings or bag to see where the tiny leak was coming from, but topping up wasn’t a real issue (and I’m lazy ;) ).
The new tyre per se couldn’t have affected it, unless something happened during install, but you only undo the bottom shock bolt to replace a tyre, and don’t go anywhere near the bag or it’s schraeder valve. Just a quick test to see if it is leaking at the valve - rub some watered-down dishwashing liquid around the schraeder valve connection. If you see any bubbles forming, that is where your leak is.
p.s. what pressure are you running your aftermarket tyre at.? The burning smell is a bit of a worry too - is the tyre contacting something?
Pete
Pete
I bought the bike last spring. State inspection for PA was in the fall and it took a new tire, so I read the forums and decided on a General Altimax 43 (my garage did the work) at 20 psi. I could feel the stiffer ride but, no worries. Then I rode 2 up. Like I said, no hard jolts but when I hit a bump there's a 2 sec burst of burning/rubbing rubber. Again, we're not skinny little kids.
My first hypothesis was that the stiffer sidewall doesn't "give" as much as the Kendra so it briefly touches the fender at bumps, but now I know I can adjust the suspension a bit.
When I rode on 2 wheels, I knew my bike and how to adjust the shock. This is still new to me and that's why I appreciate all the advice. For now, baby is under her blanket (cover) and on a tender, but when I get a chance, I'll pull off the cover and the seat to check things out.
Thanks again, Gary
Pete
Many, many thanks to all my new Ryder friends in this forum. Yesterday, in PA, it was mid-50's and sun, so I broke baby out of her covers, pulled the tender, and we made an ice cream run. Beforehand I checked under the passenger seat, found the schraeder valve, and found out the pressure was 0 (zero). That explains a lot. I pumped it up to 60 psi and rode 2-up with no problems! This morning, before packing baby away again, I checked, and the pressure is about 50 psi (could be because of the cold?). At least now I know what to look for.
Thanks for all the advice. After 50+ years of riding 2 wheels I'm still learning how to work with a Spyder.
I pumped it up to 60 psi and rode 2-up with no problems! This morning, before packing baby away again, I checked and the pressure is about 50 psi (could be because of the cold?).
Most likely a leak. Check the Schrader valve first, then all connections. Last, and most difficult, check for leaks in the air bag. There are a lot of discussions here about air bag leaks.
:agree: with IMS (above) I don't think the Temp would have that much of an effect... 10 lbs in one day?? I think you have a leak in the system... first check is to make sure the screw-in valve inside the Schrader valve is tight... if it is, you need to start spraying soapy water on the parts to find the leak... GOOD LUCK ... Mike 👍
I find that when disconnecting the air hose from that valve I lose enough air to drop the rear end an inch or so. The airbag is so small that it doesn't take much to lose what pressure you've just put in, just by removing the air hose. Any ideas?
What I would like is an adaptor containing a permanently connected air pressure gauge with a tap so when disconnecting the air hose, no pressure is lost.
That's too much air loss, unless you're taking a minute to get the hose fitting off the valve instead of just a second or so?! :shocked:
It sounds like you have no valve inside the threaded Schraeder casing at all, or maybe more likely the valve in there is defective/not seated properly & so is leaking out more air than it should/quicker than it should?? :dontknow:
Do you know how to use some spit to check the valve for leaks; have & know how to use a valve tool so you can back it out a tad & re-seat it before checking for leaks again; & maybe a spare/new valve to replace the one in there if the old one won't re-seat & seal properly?? ;)
Failing all that working for you, maybe you need a Quick-release fitting on the end of your air hose?? You shouldn't lose more than maybe a pound or so of pressure during the release process; any more air pressure loss than that, there's something wrong, or going wrong during your air hose release... :rolleyes:
My OEM Kenda at about 6,000 miles.
Plenty tread on the shoulders, center almost slick.
Replaced with Kumho All Season.
Andrew, I found similar results when using a battery operated pump. I’m not really sure why, as the pump heads take the same amount of time to remove from the shraeder? The bag is only very small. I switched to a small push bike pump and only lost a couple of psi. The manual does say not to use a powered pump on the bag due to its small size.
Pete
:agree: with IMS (above) I don't think the Temp would have that much of an effect... 10 lbs in one day?? I think you have a leak in the system... first check is to make sure the screw-in valve inside the Schrader valve is tight... if it is, you need to start spraying soapy water on the parts to find the leak... GOOD LUCK ... Mike :thumbup:
X3 Soapy water is where I would start just to see if there is a leak. For the most part you should be able to set it and forget it. I only check mine once a season when I bring it out in the spring and do my oil changes and fluid checks. If the bag was run at 0 pressure, I would check the bag really well - you may have pinched a hole in it. Soapy water is your friend.
I run the same brand tire on our Spyders as Rapidspyder does.
Started with my F3s and liked it so much I had them (all three) installed on my wife's F3l. She was amazed at how much smoother and better handling her F3 was. When we traded her F3 in for her RT we had the dealer switch out the tires. Got around 36,000 miles on her back tire - it should have been sooner, it still had tread, but thinner than I like. Mine will soon have 30,000 miles on it and I will replace it.
So far of all the different brands of tires I have run (6) on our Spyders (over 200,000 miles combined) these have been the best for handling dry and wet roads as well while providing a smooth ride with outstanding mileage.
I had the same problem as the original poster with the stock rear Kenda.
The interior of the tire was on the wear bars and the outside looked brand new.
My wife always rides with me and we ran the recommended tire pressure at 28psi.
I just replaced the Kenda with only 4,500 miles on it and replaced it with a Kumho at 20psi.
