Car tire pressure 2011 Rts Limited
Ghostpepper
I put Altimax RT43 tires on the front and rear of my 2011 Rt...If anyone is running these or another car tire, would you please tell me the psi you've had success with?
Thank you...Kevin
I’m 16 lbs on the front (Vredesteins) and 18 lbs rear (Altimax43)
Both Peter Aawen & I ( tire science proponents ) agree this PSI is what works for ALL Auto tires ..... adjust one up if you are aggressive or are near the weight limit for your Spyder, Towing is not a factor ...... good luck
Coopers on the front and Pirelli on the rear 16psi front 20psi rear on a 2012 RTL
