Rear shock adjustment gone wrong, now what?
Twodog185
While adjusting my shock, I though I had one more level to go...but no....it snapped to the lowest setting. Clunk!!
The socket flange is now around the back side of the shock and the swingarm is too close for it to keep going around.
Now what??
Yeah. Now, I have my shop manual on order.
If I raise the rear wheel, and remove the top bolt, will the wheel drop and allow the shock to fall out?? If done that way, what will the spring tension be like?? Should I wear a helmet? Is the procedure to loosen the top bolt with the wheel on the ground, raise it slowly until the shock is extended far enough to remove?
Loosen top bolt.
Raise bike at center frame until bolt wiggles
Remove bolt
Raise bike until shock falls out
Adjust as necessary
Replace shock in top mount
Reverse removal procedure.
