250 miles from home and a buddy notices my mud flap rubbing and melting. 300 miles on it. Likely going to cut it off and let dealer replace. ��
your brand new S to S???? wow!!! i would bet your air bag is NOT working, another thing for your dealer. or air ride adjustment is off
How does one check that the air ride is connected?
Same thing on my new 2024 RT....250 miles from home and a buddy notices my mud flap rubbing and melting. 300 miles on it. Likely going to cut it off and let dealer replace.![]()
I recently found on my 2020 RT base that the rear mud flap was loose....I remember hearing a noise when going over a speed bump in a neighborhood a few days ago, but thought nothing of it. I cut off the lower 3+inches of the flap since it was damaged, and hope I have no more issues with it hitting things. Since I don't have an enclosed garage, I'm waiting for warm weather to reinstall the flap.Same thing on my new 2024 RT....
What size tire do you have, did you put a car tire on and oversize it?I recently found on my 2020 RT base that the rear mud flap was loose....I remember hearing a noise when going over a speed bump in a neighborhood a few days ago, but thought nothing of it. I cut off the lower 3+inches of the flap since it was damaged, and hope I have no more issues with it hitting things. Since I don't have an enclosed garage, I'm waiting for warm weather to reinstall the flap.
- air bladder pressure @ 70psi
- OEM top case
- heavy rider
- creeping over speed bump
Thanks. The rear tire is Vredestein 205/60R 15... so, a little narrower and a little higher profile.What size tire do you have, did you put a car tire on and oversize it?
I've also been pondering cutting off the lower 3" at the cut line. Still plenty of rear protection.I recently found on my 2020 RT base that the rear mud flap was loose....I remember hearing a noise when going over a speed bump in a neighborhood a few days ago, but thought nothing of it. I cut off the lower 3+inches of the flap since it was damaged, and hope I have no more issues with it hitting things. Since I don't have an enclosed garage, I'm waiting for warm weather to reinstall the flap.
- OEM top case
- heavy rider
