I have a 2021 LTD that has a led brake light out. Dead certain it is defective.
Anyone ever had this problem?
Skip H
I guess that I should have been clearer in what is wrong.
The left rear brake light, only the brake led light, is out. Turn(bulb) and led parking light both work. 12 volts to the white wire going into the light housing when brake is pushed.
Sorry that you don't understand what I think I said.
To end this posting, I have a fair weather tail light, Yes, that is right. The light won't come on under 65 degrees, At @70 degrees and above it turns on.. Go figure that out. Yes, it is repeatable..
How do I explain this to the dealer? Stick it in the frig and try it? Na, that won't work, I'd have to take it to there and if the shop is heated and the light works?
I already ordered a new tail light and should be here in a couple of days. End of saga.
Hmmm eleven modifications, all of which required some removal of bodywork, mechanical modification/change, and/or intrusion into electrical system, at 708 miles. I wouldn't ask for dealer warranty service on an electrical problem either.
Experience with similar & is a loose connection, temp change allows movements from expanding contracting metals& components. Soldering if/where possible is the fix.Sorry to Hear,,,,
The New tail light should END your problem!
You will get the Bugs out before spring....
......:thumbup:....Bill
indicates part of the problem we've had diagnosing your lighting failure.PS: I have most of the modification setting on the bench waiting to be installed.
