Nudels2u75
2012 RT Limited Rear Brake Pads, As I was replacing my rear Pads, I can not get the back bolt back in, I was not able to get the nut loose that holds the spool on that the brake cable runs on...The brake fault light blinks.
I used a ratchet to attempt to loosen nut and was not able to do....If I could get spool to move just a small amount I would be able to get bolt in...
While I was working on this I noticed my muffler was just hanging, the rubber groument had come through the frame...somebody had put the fender washer on the wrong side of the frame...Also noticed shop had left several screws and body fasteners off
Any suggestions on how to get that nut loose on the brake cable spool...do I need to use a cheater on the ratchet or will I brake something...
