I was changing the rear tire and had to wait on the o-ring between the sprocket and hub. During that wait time, and with the caliper suspended in air, I inadvertently pushed the brake pedal. I cannot get the caliper piston to push back into its bore. I push lightly on the brake pedal and the piston moved outward and the parking brake cam also pushes the piston out further: these were very small increments. I've opened the bleed fitting to let displaced fluid out without having to go back through the vehicle brake lines. First tried the flat screwdriver, then advanced to a C-clamp. I've been servicing our Spyders since '08 and this is a "first" for me.
So, experts (people with better experience than I), now is your time to shine: what is the trick to get the piston back into its bore so I can install new brakes pads?
Wayne (I only think I know what I am doing)
