jmcbow
Ok, I know this has been discussed but I'm going to bring it up again.
I took the RT in last week for it's first oil change and inspection. One of the "rare" things I complained about was the darn rattle in the windsheild anytime you hit rough or uneven pavement. Someone had posted that they took the windsheild off and added felt washers between the shield and the mounting arm. I mentioned this to the dealer as a possible fix. They did throw in some rubber washers/o-rings, which helped, but it still rattles pretty good when you hit rough pavement, even when the windsheild is all the way down. Before I take it back again, does anyone know if BRP is looking at this and other than felt or rubber washers is there some other permanent fix for this problem? I just don't like hearing that rattling and I believe over time something is going to break or wear out. :helpsmilie:
