BajaRon
Well-known member
Sooooooo. Update after discussions with the Ikon owner, Ron ……
The idea of the extra 10mm on the “special” Ikon shock is to give you a 4 mm vertical head start on raising the Spyder body, thus limiting big preload increases, which Ikon are always concerned about on the Spyder due to its touchy front end geometry. The extra 4mm of vertical height from the “special” shock is primarily for those who want to gain an overall 10-15 mm of height from stock, but a wheel alignment would then have to be performed if they went that high.
Geoff (Ikon owner) was quite happy with my 1.5 preload turns on the stock Ikon giving me an extra 5mm, but said he wouldn’t take it much more than that due to potential harshness of ride, even with my 300+lbs. So since my 5mm of gained vertical height on the stock Ikon shock is pretty close to achieving my clearance goal, I am going to leave it at that, and put on a couple of 165/60 Goodyear Duragrip for a few more mm. I figured I’d stay with the 165 rather than moving to 175, and be a pioneer with the Goodyear Duragrip. Goodyear work pretty well out here. Hopefully, as a “pioneer”, I don’t simply end up with an arrow in my backhyea:
p.s. Geoff’s wife has been banned from providing any future advice to customers:roflblack:
Pete
It's not so much a gain from original ride height. Though you can do about 1/2" without significantly affecting alignment. It is more about regaining lost original ride height from loading. The heavier the load, the more suspension sag you're going to get. The bike comes with soft suspension settings for the AVERAGE person and loading. Not only can this allow a 1.5" or more of initial sag. But it also allows for exaggerated body dip when driving through depressions or over humps. Upping compression dampening a bit, if your shock allows it, and increasing preload, if done reasonably, will give you exactly what you are looking for. Just recovering that initial sag is going to be HUGE! Not to mention eliminating some unwanted lean and dive in turns.
There is harsh, and there is additional control giving you a more taught ride. I don't see additional control as necessarily being harsh. I can't imagine that experimenting with another 1/2 turn or so would do you any harm at all.
It's all about enjoying the ride! Tinkering and tweaking the ride can be fun!
