leveling blocks for rv's work and are easy to store. Did make one change, l now use a tapered stack of 2 2x6's 20in. long with pins to keep the center blocks from moving.
Very interesting setup Navvet. Did you buy those extra 2 ramps or build them?
View attachment 163398View attachment 163399
New Toy Hauler. As you can see I have to back it in due to the length of the Spyder. I was trying to get the smallest Unit I could find and still fit the Spyder in the garage area. This is the new Wildwood 260RT as the 180RT would not quite fit the Spyder. I used Level blocks to give the Spyder a bit of a lift to clear the steep pitch of the ramp. Guess I'll be building me some ramps to carry along. I did pull it farther back to put most of the weight over the axles. Don't want to install an additional ramp to the existing as this also works as a patio deck as well, But I am open for suggestions.
View attachment 163415First generation Jayco Senecas can have lift gates! Problem solved.
Unfortunately: I'll bet that's the (No longer in production...) ZX model. :shocked:
Actually Bob, it's a half ton pull RV. I've attached a pic with demensions, and you can see why I have to back in. I was actually trying to go smaller, but just couldn't quite fit the Spyder.TexAm...
That's a nice-looking rig! :clap::thumbup:
It looks as if you've got about a 10 foot long garage... Mind is only 9, and it's a bit... Tight! :shocked:
I pretty much figured that out; when I saw the kitchen sink and it's cabinetry along side of your bike. :thumbup:
It looks like a really nice floorplan: what brand and model is it?
BTW: Most Toyhauler "5-ers" have a dedicated garage space. That's how I figured that yours was a TT...
