Question ? installing NMN risers on SE5
RoadHammer
Im almost done installing the risers, trouble free so far except for the shifting unit cable and high low/beams signal light cable assembly.. They both run underneath a steel bracket of somekind underneath and have no idea where to look to get to cut any zip ties. I can't get any free length from them whatsoever. Has anyone done An SE5 or can give me some advice, I have been under the hood and removed the fuse panel cover, both side panels are also removed.
The wire bundles enter the top frame member next to the steering shaft, and exit the front and get plugged into connectors at the front frame. That's where I clipped the cable ties.
It also makes a difference on the position of the extensions as far as resulting cable slack. If they are rotated more toward the rider, the slack increases; if they are rotated toward verticle, the wires and throttle cable get tighter.
Hope this helps. If the image is too grainy, send a PM and I'll get you the high res photo.
Wayne
Yikes, your bike is nekid..... My throttle side is good, looks like i need to get to the "cut ties here" you have pointed out on your pic..
Thanks bud, will let you know when i get it done.
