Spyder Hawk
Has anybody removed the electric windshield switch from inside the left handlebar cluster? There is nothing connected to it as far as I know. It's covered by a little glued on plate and the actual switch is inside the housing. The external rocker is the only thing missing. Problem is that it is a momentary switch so I can't tap into it. I need to install a push button switch but there isn't room for it. If the old switch electronics could be removed then it would be no problem. I just don't know if it can be taken out or if it is a part of something that has to stay in place. Any BRP guru's out there that can shed some light on this??
