cognaccruiser
2014 RTS
I replaced my rear tire and am putting the thing back together. I have the tire bolted on, cotter pin in and shock bolt back in. I had used tape on the adjustment blocks to try and make sure they didn't move out of adjustment. I had pushed the tire forward while tightening the nuts to try make sure there was no play in the blocks and much to my dismay found that there is a little play in the blocks.
Obviously the wheel isn't quite where it should be and I have to fix that.
My question is: Do I need to take the shock bolt back out or can I leave it in and just loosen the nuts holding the wheel in place? I guess I will have to try pushing tire forward more while off the ground and tighten it again and then lower the Spyder down so the wheel is touching the ground and tighten the nut. I thought I saw somewhere about tapping the nuts/axel assembly forward with a mallet or hammer to tighten up the adjustment blocks before tightening the wheel nut.
If I'm off base in my assumptions tell me. I'm all ears and I'm tired right now and want a break anyway. :sour:
Gary
Gary
