Pulling rear tire
Hi,
Yes remove air level sensor lever upper bolt (10mm socket and 10mm wrench on nut).
Let air out of blatter.
Remove rear axel cotter key & 36mm nut (100 ft # tight).
Jack up rear wheel.
Remove lower rear shock bolt (15mm).
Remove 2 (15 mm) bolts holding rear Brimbo brake caliper, support the rear caliper.
Pull axel bolt.
You only need to remove rear brake disc from rear wheel.
Note: Discount tire will mount your new rear tire for about $8.
Put 16 oz of Ride-On in rear tire to balance it while riding.
Re-assemble rear wheel.
Enjoy your beautiful ride coming up!!
The 2014 Spyder RT's are awesome!!
Jim
Question: How do you let the air out of the Bladder?
WHAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAT
Can you give me an idea of where this would be under the seat? I've peered under there, but nothing grabs my attention.
Thanks,
Pam
.............It's better known as a Schrader valve ( like where you put air in your tires with ) it's just in front of the Brake fluid containers............It probably has a cap on it
MIKE :thumbup:
