flybuddy
Does anyone have experience removing the airbag? When I had first gotten my new RT home from dealer last month the airbag had zero pressure. Every time I would check it would seem a pound or two lower. A few weeks back I installed an aftermarket on board air compressor which gives a constant pressure readout. It confirms a loss of 1 to 2 lbs. per day. I've done multiple leak checks but the one place I can't get at is the fitting on the upper portion of the airbag. Looking at it from the bottom it looks like I could unbolt it (after removing pressure) and slide it out to check the top of the bag and the fitting for a leak. Has anyone successfully removed one from the bottom without removing all of the upper stuff? Thx for any help..Tom
