Ga Blue Knight
I think that I would like to pull a small cargo trailer with my 09 RS SE5. What are the pros and cons? What brands of trailers out there would be best suited? Any and all advice would be really appreciated.
I have this America's Best Tailer: http://cgi.ebay.com/ebaymotors/Trai...rcycles_Parts_Accessories&hash=item3cbb815e49
I also have this hitch. http://cgi.ebay.com/ebaymotors/Can-...rcycles_Parts_Accessories&hash=item4cf46de40e
Both work just fine. The trailer is 20 cu. ft. They make a smaller one. The hitch is similiar to the BRP hitch. It fasten to the swing arm. I also use a hopkins converter for the wiring.
I've been very pleased with everything so far. I've only pulled it about 3000 miles but it pulls behind my 08 GS just fine.
One difference in the Canadian hitch and the BRP hitch is you have to take the axle off and insert it through the hitch. It's not hard but I would recommend reading a thread or two on how to avoid having to readjust the belt after doing this. You will need a 36mm socket/wrench to get the axle off.I just looked at the Spyder hitch on ebay. If it also fits, and it should, I'll order it. Good savings over the BPR hitch. Due to some physical problems I should be able to install myself with the assistance of a couple of friends. Did you also have to purchase the BPR wiring harness in addition to the Hopkins wiring converter?
Retread(john) did my wiring for the trailer. He did a masterful job so I defer to him in questions regarding the wiring or converter. I will say if you get the trailer I mentioned, it will include a converter(among serveral other things) that you can use. However, it is not a powered converter so you would have to tap into the Spyder wiring for power. John thinks that may cause problems so we both used the powered Hopkins converter and who am I to question his wisdom. nojokeThe BRP harness is RT specific, you can't use it on an RS without a lot of modification. The Hopkins powered converter, a few Positaps, and a plug to match your trailer's is all you need. If you have an auxillary fuse block, it makes it a little easier.
john
I recently had a hitch installed on my RS.The hitch I had installed is a Bushtec with a 5 wiring harness.I am concerned about any bouncing with trailer I would have with this hitch not installed on the swingarms.I am also looking for a alum trailer.Any suggestions would help on size,weight,tire size.Do have any suggestions where I can find a reasonable priced alum trailer ? Thankyou,BootsI have an 09 RS and pull a Aluma trailer with it...over 1200 miles no issue. I have a BRP hitch and a Hopkins converter for wiring. Any other questions you can PM me.
On my 08 RS I pull a Bushtic trailer. They have a very good hitch also. Didn't even notice I was pulling a trailer while riding the dragon. :thumbup:
Frame mounted hitches work perfectly well...better than swingarm mount in some cases. Most trailer hitches are frame mounted.I recently had a hitch installed on my RS.The hitch I had installed is a Bushtec with a 5 wiring harness.I am concerned about any bouncing with trailer I would have with this hitch not installed on the swingarms.I am also looking for a alum trailer.Any suggestions would help on size,weight,tire size.Do have any suggestions where I can find a reasonable priced alum trailer ? Thankyou,Boots
I am glad to see someone else has a bushtec hitch for their 08 RS.How does yours fasten on ? What should I be looking for in purchasing a trailer ? Any suggestions where I can find a reasonable priced trailer ?Thankyou,Boots
there is no motorcycle of any make or model, except the Spyder RT, that is rated for trailer towing. There are lots of motrcycle trailers being towed, though. Dealers can be such kill-joys!I had an 09 RS with BRP hitch and trailer. I was in Wi. at one of the BRP factories and was talking to one of the gentelman there and he said "that style bike is not recommended to pull a trailer" I looked at him and told him "But it's your trailer!" Then I looked in the manual and sure enough not recommended to pull a trailer. Sooo I pulled that BRP trailer for about 15,000 miles. Didn't break anything, and had to keep looking to see if it was still there. Just be careful of WHAT kind you get and have fun.
