Progress Report: 700 Mile Mark - It's True!
newbert
Well, I'm finally over the 700 mile mark on my odometer (actually broke 800 today....), and I've found that what many on these forums have said is absolutely true. At about this point, I'm feeling much more confident and less nervous on my F3-T that I did earlier on. In fact, I have to work at resisting over-confidence at this point.
Ryding on the same roads I have been earlier, I find that I'm taking curves much faster than I did before.
I have a few questions though.....
1. What do you guys do to prevent or reduce your right hand falling asleep? Mine falls asleep about 20 minutes into a ride - almost every time.
2. Related to that, how long do you guys usually ride for (time-wise, not miles) before taking a break? By "break", I mean getting off the Spyder and stretching the legs a bit?
Finally got on the Interstate today too (for the first time), but for only 2 miles or so. Not my favorite type of riding.....
Thanks!
Check it out
Look up cramp buster I use one and like it a lot
Prefer scenic routes, stay off the interstate unless I absolutely have to
Thanks!
There you go....
sounds like you are enjoying the whole learning experience. :clap:You can try getting the foam grips that slip over your stock ones to help with the sleeping hand and it may get better with time especially if you loosen your grip. Everyone will have different ryding styles, seat times, mileages etc. I ususally ryde till I need gas then take a break This would be about 2.5 to 3 hours if traveling. Back roads with lots of fun hills twisties etc usually about an hour and then find a nice vista point. This is if I am with the wife alone I will go forever if the gas did not run out..:roflblack:
I utilize the cruise control a LOT even if only for 20 seconds at a time. It gives my right hand an opportunity to relax, stretch, etc. Even on residential roads, the cruise control for a brief time is great.
Regarding the cramp buster - it doesn't seem conducive to changing speeds frequently. I'm not sure how practical it would be for riding on state and county roads in rural areas. Seems to be meant more for Interstates, no?
But maybe, I'm completely wrong about it? :dontknow:
I agree I use the cruise control on short/long trips. Deanna
I use a cramp-buster, and only ride on back roads; as twisted as I can find. I have arthritis and have no choice but to use one. A cramp-buster works well when having to constantly change speeds; unlike a cruise control, which locks the throttle to a specific speed.
Cramp-buster simply allows you to use your wrist more to turn the throttle. Once you get used to it, which will happen instantly, you will not have any trouble with constantly changing your throttle.
Fitness
Riding a motorcycle is a sport. There is a set of muscles you are using that you had not before. To that end, get a tennis ball, and squeeze it while watching tv. Both hands. Lots of stretching exercises, and squats and wall sits for the buns. With practice, you can go a full tank, gas up, walk around, stretch, and ride more. Just like you have to do to get ready for ski season, or swimming, or hiking. That, and practice. Practice riding, turning, swerving, emergency braking, and backing up. Look how far you have come in 800 miles! Add a zero, and then see. Add two, and you will look back and see! Enjoy!!
No Newbert, you're not completely wrong! :lecturef_smilie:
With a the right sized cramp buster fitted you can use the heel of your palm instead of your fingers to control the when & how much throttle twisting stuff you do at virtually any time, & that means your hand can be more relaxed all the time & that you can move your fingers at will without necessarily changing the throttle setting. All of which adds up to greater means of control, a more relaxed throttle hand, & more flexibility in how long your hand needs to stay in any one position/hold any one grip, so thst you can avoid that 'hand going to sleep' issue! ;)
There are many Spyder Ryders here with hand & wrist issues of varying degrees as well as ryding styles & practices of all types, but I still reckon I'd be safe to go so far as to say that EVERYONE who uses a cramp buster gets some degree of relief from it in any &/or all of their throttle use, including in those less open state & county roads you are concerned about & even on tight hilly & twisty roads with lots of need for constant throttle variations! I know that with my right hand (that has a prosthetic thumb joint, damaged nerves & tendons throughout the rest of my hand, & a severely compromised wrist) I still have absolutely NO issues using the cramp buster equipped throttle in any circumstances while ryding, & I have been known to tackle the twisties & back roads that need frequent & constant throttle adjustments with much gusto, speed, & enjoyment (much to the chagrin of many sports bike riders & wannabee racers! :D) simply cos the cramp buster makes it all easy & possible! :clap:
But also, like many others have mentioned they do, on some days I too have been known to use the cruise control at every opportunity, be it out on the open road, in congested city ryding, & frequently even in the twisties (set it to your chosen max speed & then use dabbing the brakes or changing gears to cut it off before a corner & then just flick the resume button to use the cruise setting to accelerate out & down the next straight, however short it might be! ;) ) And the cruise control is a real joy on the many loooong straight roads we have here in Aust too! :thumbup:
You just gotta think a little outside the box, & try to work out how best to use the tools & controls you have plus any mods you can readily make/apply to make the best of or improve your ryding enjoyment! :2thumbs:
Cruise Control helps a lot, now that you're past your break in period use it more. Open and stretch your hand right after applying it, it helps big time.
Peter. Thanks for the detailed reply relating your experiences. I think that I might give this a try. I see that the crampbuster comes in 2 different size diameters (at least that's how it seems on Amazon....). Do you know which diameter is correct for the F3-T?
Thanks again!
..... Do you know which diameter is correct for the F3-T?
Thanks again!
Sorry, one of the local dealers had a bin full of them by their door, & I just played 'try it & see' until I found one that fitted on my RT hand grip in a way I liked.... :dontknow:
I think there were actually 5 different sizes, and about 3 of those would fit my 2013 RT, but with varying degrees of tension on the stock grip. No matter tho, cos they were made of 'poly something', basically flexxy placcy stuff, so that even with one that was 3 sizes too small, the bit that went around the grip still flexed out enough for it to go on & work, it just grabbed the rubber of the OE grip tighter & looked like it might wear a groove in it over time. Going too big might be an issue, the cramp buster won't hold the grip securely & so won't work, but I don't think going too small would really be a problem! But if you are really concerned, I reckon a bit of heat from a hair dryer or heat gun would solve any 'too tight' issues in about 5 seconds! They were bloody cheap when/where I got mine, I think about 20 cents each, altho maybe the dealer was just selling old 'loose stock' so he could put up a new 'card rack' or something on the counter to grab those 'impulse buys'! With that in mind, it might be easier just to visit your nearest bike shop, or anywhere that sells motorcycle clothing & accessories - if you go on-line I suspect you'll pay more for delivery or postage on one of these than 10 of them would cost, & they seem to be a cheap 'change grabber' in just about every bike shop I've ever been in?! :thumbup:
Edit: I just took mine off the RT, & I reckon it's about 30-32mm dia. If you must go on-line, try searching 'Universal Throttle Assist Wrist Rest'.
FWIW, Just got a crampbuster and tried it on a 100 mile ride. It worked great. That was my longest ride to date, by far, and I had no issues to speak off with regard to hand discomfort.
Thanks guys!
The foam grips do help, add in the cramp buster as well. It gets better. I think Lamont or Spyderpops has the grips. :thumbup: Tom :spyder:
:agree: I use the cruise control as well. I find when I can't due to traffic or whatever, I suffer from the same sleeping hand syndrome. Using the cruise with short periods of manual throttle control, I do not have any hand issues. We typically got for about an hour to 1.5 hours and then we take a break to stretch our legs.
