ntxYguy2009
Problem Shifting 2010 SM5 RT-S
Howdy Everyone,
My 2010 RT-S has been sitting in the garage for a few weeks. This morning I was going to ride it to work. I turned the key on and noticed that it was not in neutral. I was standing on the right side, pulled the clutch in with my left hand, leaned over the bike, and pulled up on the gear shift gently with my right hand. The Spyder acknowledge that it went into neutral (green "N" appeared on screen). I then pressed the Mode button and flipped the kill switch on. After a few seconds, I pressed the starter button and the Spyder started up. I let it run for a few minutes while I moved the trailer and other motorcycle out of the way. When I came back, I got on the Spyder and attempted to put it into Reverse. I squeezed the clutch and noticed that it did not require much effort. While holding the clutch in and pressing the "R" button, I pressed down on the gear shift with my left foot and it would not "click" down. I tried shifting into first. It finally did this, but it became very difficult to move the gear shift.
Any thoughts? There were no leaks detected underneath the Spyder. No noticeable issues during the last ride.
David
Howdy Everyone,
David
