Yes, I purchased the cable directly from Garmin and it works just fine on my S2S
Can you tell me what the cable is called or how you found it. I have searched the Garmin site without success. I am trying to connect a Garmin DriveSmart 60 to the front USB port.
Thanks
Thanks
Has anyone tried to power their GPS from the USB cable provided in the front glove box above the dash?
I can only speak of my 2021 RT LTD. My Garmin GPS sees the computer on the bike if I use a standard USB cable to connect and goes into maintenance mode (map loading mode), so I opened up the cable and cut the green and white wires (data connections) leaving only the red and black wires (power and ground). This only sends power to the GPS and it now functions normally. I have another standard cable I use to connect to my computer for updates.
We use a data blocker on the USB from the glove box, less than $5. a piece on Amazon, That just gives the power and doesn't hijack your equipment. :thumbup:.....Bill
Just a doubt. Power from globebox USB is 5,3 V. and Garmin GPS needs a 12V power wire. Is this correct? If yes maybe It shoudn't go.
Yes, which is why the direct wire from 12v to cradle is the designed method. The USB is normally only used for off-bike charging or PC hookup but can work as a backup power source..
I agree completely. Why would you not use the dedicated gps power supply on the bike and keep the usb freed up for others things?
