NancysToy
Motorbike Professor
Unfortunately, the sensors and the fuel maps work only off the air pressure and temperature (indirectly calculating air density) and a fixed air-fuel ratio in the mapping. The ECM fine tunes this under certain conditions. How well the mixture fires in the cylinder doesn't matter...only whether or not there is excess fuel in the exhaust during closed loop operation. Perhaps a system could be designed to monitor combustion efficiency and compensate for it, but it doesn't exist on the Spyder. Also keep in mind that the air temperature is not the combustion chamber temperature, which is quite constant once the engine warms up, so combustion efficiencies remain fairly constant. The ratio you have seen is merely coincidence, IMO.Colder air is denser as you mentioned, but it is much easier to cause an ignition when there is more air available. Because the air is denser and thus more abundant, more air fits within the combustion chamber, making ignition easier. Should require less fuel. Air density at 120° is about 20% lower than density at 30° (this is not an exaggerated seasonal temperature difference for Vegas). This is an almost direct correlation to the approximately 20% decrease in fuel milage I see in the summer months. Instead of adding more fuel to achieve the needed fuel to air ratio, wouldn't it make more sense to allow less air in instead to achieve the desired ratio?
