po339
Mortis
Hi i have washed my 2012 rs-s and it will not run properly.
I get the code po339 after trying to start it.
It was like this the last time i washed it also.
But then it started after drying
Is this a known problem?
P0339 CPS crankshaft position sensor , disconnect CPS measure resistance between pin 1 and 2 of CPS , expect 850 to 950 ohms , I think it is only water in the plug you can disconnect and spray contact cleaner and dry it out , it will be ok
PO339
Hi
I also wonder if i have found the right connector, have been washing the spyder many times and it is always hard to start again (code PO339)
is it the grey connector on top of the oil tank ??
I was loocking for an drawing of the engine with the wiring but cant find it.
Morten
