Dwanton
took about 3 hours - not too bad if you take your time .
you have to remove the side plastics , the trunk and upper dash to expose all the wiring and to install the new wiring harness.
this is a factory can am kit
have to remove front pieces and remove the old bezels
the tabs are held on by little clips that just pop off
remove the windscreen and insert a small screw driver to pop out the gauges.
unplug the gauge cluster
unplug the turn lamps going to the mirrors
the dash just slides forwardsafter 4 bolts are removed
cut out supplied template for where the switch goes.
attach fog lamps to the trunk
put her all back together
