Dwanton
installed some new stuff
the comfort seat was easy enough to install and is very nice .
the sport rack went on first while i had the seat off -- this is a must have if you want to install a rear passanger back rest . nice thing is that under the lid is a nice small storage space that has a rubber gasket so looks to be waterproof. it comes with a pull cord thingie that goes under the seat and you pull it to take the cover off and switch to the backrest -- very easy and very secure.
the console protectors are from can am and match the carbon fiber look of the front decals in the handelbars.
the yoshimura pipe sounds great -- only problem i had was attaching the upper bracket on the pipe and getting the bolt through it -- ended up spraying some WD40 on the rubber gasket so it would let the bracket slide together easier.
the rear seat solo cover is just held on by rubber bungies -- holes are pre made into the seat , yes even the comfort seat is identical underneath as the other seat. i am just not sure i like the look yet -- might have to wait a few days and see if it grows on me.
now tomorrow i put on the two brother juice box pro -- just have to see if the two brothers map will work with the yoshi pipe.
still waiting on the trunk liner to be delivered by the big brown truck.
