The Headlamp Relay (R2) is fed by a 30 amp fuse, but that fuse also serves the 10 amp foglight circuit, which is not relay operated. The Cooling Fan Relay (R4) is fed by a 15 amp fuse. Both these fuses feed both the relay contacts and coils. Main Relay 2 (R3) is fed by the main 40 amp fuse for the contacts, and a 10 amp fuse for the coil (shared with Main Relay 1 coil). The Main Relay 2 contacts feed 4 fuses down circuit, for a total allowable load of 23 amps. Main Relay 1 (R1) contacts are also fed by the 40 amp main fuse. These contacts feed two fuses down circuit, for a total of 25 amps.
Good electrical practice dictates that the any components should be able to carry at least as much amperage as the wires that feed them and the circuit protection (fuses). That would dictate a minimum of a 30 amp relay for the headlights, a 15 amp relay for the fan, and 40 amp relays for the remaining two. Only the stock Tyco fan relay meets this standard, although the load for the headlight relay is probably within limits unless a short circuit develops. The large VF28 Main Relay 1 meets the downstream circuit's requirements, but at 35 amps, is rated slightly below the load of the main fuse. Substitution of the smaller VJ28 relay in this position appears to be insuffiecient for the load, if the Spyder's circuitry has not been changed to accomodate the smaller relay. The possible load on Main Relay 2 exceeds that relay's continuous current rating.
From what I can find, the Tyco VF28 relay is a standard unit with Form A contacts (make-break). The three VJ28 relays are apparently specially ordered from Tyco in a higher rating than their standard VJ28 relay. The Tyco data sheet says this is possible, and it explains the non-standard part number. These would appear to have a Form C contact (changeover), but are used as make-break on the Spyder. It is all very confusing.
As a result of what has been posted here today, and my research, I am no longer comfortable using the Duralast relay as a spare. I will buy one of each of the BRP relays, although they do not seem to be as reliable as they could be...or of sufficient ratings for the most part. They are rated higher than the auto store replacements, however.
-Scotty
