dI was thinking before this but just came up with an idea. It all looks goo to me except the inside of the vent. I was going to make suggestion before to paint it flat black and it just donned on me...duh.... Plastidip would look great behind the screen and be removable it you did not like it. Too bad it is not 90 deg so we can get a report on the effects. I also wonder the difference between those and the adjustable BRP vents. How much $$ do you have in the uppers? I hope you are not paying for the grommets I would be blaming BRP/dealer for them missing.
after i put them on i said the same thing. so i have the whole winter to take them off and paint the inside black
It will how much :dontknow: We will be needing some temp readings when it warms up. Maybe BRP should be sending us some :roflblack: Once again how much $$ for the uppers? Yellow (like white) is one of the easiest to match paint wise even a little off tint doesn't show much.like i said b4 it needs a lil tweaking because grommets were missing from when they did the heat fix. so i didn't put them on with all the screws because i need to replace the missing grommets and they were ordered today. so when they get here i will take it apart to replace the grommets and do the black paint on the inside of the vents. i am very happy with the way it looks now i just hope it helps a lil.
I would hold off on the FB's they are a little busy (fugly?) I think you have done enough to at least measure the vents. When you doo to much at once you do not know what really helped. I thought I saw your post about pre painted ones how much did they charge extra for that option?upper vents are 595 canadian
lower ones are 595 canadian that just in primer and no shipping
and my next thing i want to do is the floor boards as soon as i get some money they are 1850 canadian
I would hold off on the FB's they are a little busy (fugly?) I thin you have done enough to at least measure the vents. When you doo to much at once you do not know what really helped. I thought I saw your post about pre painted ones how much did they charge extra for that option?
the ppg code for my yellow was not the right color because i gave the painter this chart that is why he used the paint i bought from touch up direct
