Parking brake audible
exwinger
Question....If you do not engage your parking brake and you take the key out , do you get an audible beep ? I don't know if the manual says you're supposed to or not , my bike is in the shop so I can't check it out. Mine has never beeped and I never use the brake when in the garage. I was walking thru a parking lot and noticed a guy sitting on his spyder and it had an audible beeping noise. I walked over and started talking to him and asked him what the noise was . He informed me that it happened every time he took the key out without setting the brake and sometimes it wouldn't shut off without trying the key several times .Audible was very loud . His was a 2012 limited. I've been on several rides with spyder groups and never heard the beep but then maybe they always set their brake ?
The SE version will beep if the key is shut off without setting the brake. The SM versions do not.
If and when I forget to set the parking brake on my 2011 RT LTD (SE), I get the beep, but I don't worry about it much when it is in the garage, it will turn off after about 20 secs.
