I can fix it, with a small washer or some tape or something, I just wanted to see if the piece wasn't that expensive I might replace it and to a better job on it next time. But I COULN'T FIND IT and my OCD kicked in I guess...Mike if you think it's part of the backrest, then yeah, I won't be replacing it.
Thanks for everyone's help on this....maybe now I can sleep tonight........................................................................................... .......... Dear Tim, because I was using a parts Fiche', and although I've had that backrest off 10 or more times, I've never thought about it in regards to your problem !!! ... So I took mine OFF ..... well the backrest assembly isn't ONE PIECE :lecturef_smilie: ..... That Flat piece is separate and attached by FOUR hidden Plastic POP rivets ( removable ) .... So now if you really want to go further - on your Spyder - loosen the two screws on top and remove - three T30 bolts on the flat part and take the entire back rest OFF ..... you can either take this to your dealer and ask THEM if they can get that piece ( that sticks out ) or un-due the pop rivets and get the part number imbedded in the plastic ......... Mike :thumbup: ........Continued on Post # 15 :yes:
