P-Codes received this morning :(
dadunston
Hi Community,
I received the following codes this morning on my 13' STS limited.
C-0051
C-006C
I cut my trike off, back on, and all seems to be well again.
IS this something I should be concerned about?
Yes, you should be concerned with any fault code on a new machine.
C0051
= SAS adaptive fault...Wrong steering angle sensor mechanical position during reset or no intialization after part replacement
C0051 = Steering position sensor failure...Defective steering angle sensor (SAS), wrong sensor mounting, steering agle sensor not yet initialized calibrated, Loose magnet on DPS output shaft
C006C = VSS CAN message plusibility error... Communication intermittent, erratic, or checksum error.
These indicate sensor or communications problems, and should be looked at by the dealer...especially those that are involved with the steering. From what I hear, steering is pretty important. :D The VSS error could have been triggered by a faulty SAS sensor.
