Orange transmission screen
Rukpub
Hi All. The transmission screen came on today after a highway ride on My 2012 RTS SE5 the can am started to sputter and the reverse and neutral lights started flashing. I kept rolling on the throt to gain power to get out of traffic and it jumped a few times until I finally found a parking lot. Shut it off for 5 min started it up and made it home about ten miles with no trouble. I did notice that after I put middle grade gas in on the way back from todays ride it felt like it was running a little rougher than usual. has anyone run into this problem? if so what should I do. Thanks in advance.
Try to pull up some codes so we can help you with your problem you might want to check the oil level and gear position sensor
