Optimal shifting range for the 1330
My 2 cents worth.......
I have noticed that when I first start out in the morning----I shift all gears at 2500 rpm. That produces a clean/sharp shift with no delay or clunky noise. As the day wears on and the temps of the oil/water & air heat up, I find that to produce these same clean/sharp shifts requires a higher rpm---2800-3000 rpm. Yes, I check my oil very often and it has been changed per the maintenance schedule. I have also noticed that at times when I shift, the machine wants to delay the shift and fall flat on its face before picking up the rpm's and going. That usually happens at rpm's in excess of 3500. Not sure what that is all about. Does not do that very often so am not planning on taking it in to the dealer just yet.
What bothers me more than that----I can't seem to get this downshifting "down". I find that, in order to not get a clunking sound, I must let the throttle go all the way back to zero and make sure the rpm's are below 2000 before pulling the rear paddle. This works great. Anything else is a guess at best---at worst a lot of clunking. I would think that to be very hard on the belt.
Anyway, that is my 2 cents worth.
Have a great day, all.
